monitor with speakers? HELP
Don't expect the earth for such a restrictive budget but your best bet is probably something like the ViewSonic VA1913WM. I'd strongly suggest you consider buying a cheap pair of desktop stereo speakers and spending your budget on a better monitor - it would be a sad waste of a GTX 460 and your SB Live if you're using it for that rig. Built-in speakers for monitors of that price are poor compared to even the cheapest standalone speakers. You could get this Iiyama for example on this week only for just a smidgen over your budget.
