Hi,
A couple of days ago, I ordered a VGA cable to connect my 360 to my monitor. Foolishly, I didn't check my monitor before ordering it as I
was pretty sure it took VGA input! But now, after the VGA cable has arrived I can't plug it into my monitor, as it only accepts a different type of cable.
I have a Xerox XA7 Series 17" LCD Monitor [Click for Spec.].
So, the type of cable it uses isn't a VGA cable, I'm not sure what kind of cable it is, I have a picture below and maybe the specs will say but i'm not really sure. I need to plug in a VGA Cable.. Is there any way I can get around this by buying some sort of convertor or something?
Picture:
http://img260.imageshack.us/img260/1369/monitor005tf4.jpg
Thanks,
Stealth
Picture:
Thanks,
Stealth
