Monitor won't turn itself off
Capodecina
1 Aug 2005
Flatland
I recently changed from using the VGA/DVI ports to the HDMI one. However, when I shut the PC down the monitor doesn't turn itself off, it just goes to the light blue screen with a 'no signal' indicator? Is there any settings I can use in the OS to make it turn off automatically?
Hi,
That aspect of the monitor can't be controlled by the OS, you might be able to find an option in the monitor's menu system that will make it turn off after a certain period of inactivity over HDMI, but it sounds like the monitor is just acting like a normal TV when you use the HDMI connection - i.e. still on, just displaying a "no signal" screen and waiting for the connection to be re-established.
I'm sorry I can't help you further...
You could try using a HDMI>DVI converter and routing the HDMI lead through the converter and into the DVI port of your monitor?
Banjo
That's what I'm doing, but I'll look for a setting on the monitor too, thanks.
In first place why even use HDMI?
In computer monitor use it's 100% useless.
Because on this particular monitor it widens the range of calibration settings.
