Monitor worth upgrading???
Permabanned
15 Apr 2010
Hi folks,
Not long finished building my new system (see sig) I pretty much only use it for gaming and internet browsing.
I was wondering if it would be a good investement to upgrade my monitor from my Dell 2407WFP I have had for about 3 1/2 years.
Max budget of £500, I dont want anything smaller than my current 24" panel and would like to get peoples opinions on the best possible monitor for gaming I could get for £500 or under.
Dont care about movies or photo editing or anything else other than best LCD for gaming.
Cheers
Gordon
Tbh, id stick with what you have, im still on a benq fp241w which came out at the same time as the 2407, havent seen anything that would make me change, ill stick with this current lcd till it dies.
it's a Rev A03...??? if that makes much difference
Thanks for the replies though!
Rev A03 is still a decent screen, don't think you would notice much differance by upgrading to a newer 24" monitor and if there is a slight improvement don't think it's worth £400-£500...maybe someone else might think different.
