Monitor
17 Aug 2010
London
Since my only monitor is screwed up can anyone reccomend a defent monitor for around £150. This will be for a new build that will be built next year but in the meantime it is to replace my old monitor. It must be over 20 inch in size.
There are quite a lot of monitors around the £150 mark. What will you be using it for? For that budget I reckon you'd be looking at something around 22 or 23 inches. One of the most popular monitors on ocuk anyways, is the BenQ G24HDBL, but its priced at 170 but very commonly is on the offers of the week. Also would look at Samsung monitors too. Might be worth reading some of the user reviews for the BenQ mentioned above. Unfortunately ocuk havent got many offers on this week for monitors.
Oops, didnt realise they dropped the price of the BenQ, was £169.99 just a couple of days ago....gutted as I probably would have got that. Oh well.
Personally I like the look of the BenQ over the Samsung. Be sure to check out the massive thread over in the monitors section fro the BenQ.
I recently went from a 19" to 24" widescreen
and ill never look back
Same. Absolutely loving 24" inches worth of screen!
Ok I'm goign to get it on october desiciion made on the first of october I will oredr and have it delivered on the 6th.
