Monitoring Registry Changes
18 Oct 2002
Sandwich, Kent
I'm about to do an update on a company laptop, however I need to monitor what changes the update makes in the registry.
Is there a program that will make a backup and then compare the two after an event?
You could do it manually without too much bother.
Export the registry before and after, then use gdiff (a DOS based equivalent of unix's diff command).
Try googling for a program called "Regshot". I've used it to check for differences before and after installing programs for users :)
