Monitoring temperatures
22 Sep 2010
London
Hey guys,
Attempting my first overclock at the moment. I'm using Speedfan to monitor temperatures under load on my CPU. My question is, which temperatures do I actually need to look at?
There are the following temperatures:
Temp1
Temp2
Temp3
Temp
Core 0
Core 1
Core 2
Core 3
The 'temp' reading are always low (~20C idle, ~40 under load) however the 'Core' reading are much higher (30-40C idle, 60-70C under load). If it's the core readings that I need to be concerned about then I think I need to reapply the AS5 and reseat the heatsink (Noctua NH-U12P). Thanks for any input guys,
Jim
The Core temps are the important ones.
Whether 60-70c under load is ok rather depends on what you are overclocking and what your current overclock is.
