- 22 Jul 2010
- Stafford
Hi,
Buying a new PC, first time since 2008. Currently have a QX9650 @ OC'ed 4Ghz, 4GB DDR2, 470GTX with a Dell 24" Ultrasharp (2407WFP-HC).
Moving to 6700K, 16GB DDR3, 1080GTX with... "some" monitors. And this is where i need some guidance.
Budget wise for the entire build is up to £4,000, so £1500+ for monitors is feasible.
Primary usage will be working, programming, photography (hobby) then gaming. Given the work aspect i will benefit from triple monitors, but i don't plan to game in triple monitors (too much GPU required) for limited gain.
Going for triple monitor, I've always wanted 3 the same, looks cool, but is it really worth it for 2 side monitors that don't get "real" usage. I also like the aspect of 3 monitors the same having similar pixel density and color temperature.
I really like GSync, so ideally the main monitor should have it. No need for 3D so 100hz or higher is fine.
Some questions
1) Given side monitors might be in portrait mode, for viewing angles is it advisable to stick to IPS panels?
2) If the main monitor is gync enabled, will side monitors require gync even if only gaming on 1 monitor?
3) Should i be concerned about the QA issues with gsync IPS panels, or just switch out if i get a bad one?
4) Get 3 monitors the same, or 1 better monitor with two cheaper one the side?
Current considerations.
Acer x34 + 2x Dell UltraSharp U2715H 27" 2560x1440 IPS
Asus pg348q + 2x Dell UltraSharp U2715H 27" 2560x1440 IPS
3x Dell S2716DG 27" 2560x1440 TN G-Sync
3x Asus Predator XB271HU 27" 2560x1440 IPS
TBH the Dell UltraSharp U2715H might over overkill as side monitors, but it what i saw on the OCUK website with the same vertical resolution as the 34"
Any recommendations?
Some questions
