Hi,
I posted a question yesterday and got a lot of help from a lot of users (thanks all) but it also brought up a few other questions. I hope you didnt mind me opening a new question
I have a great monitor at the moment and i have no problems with at all. (picture quality, colour etc..)
I am however after a second monitor to sit next to it/replace my current monitor as the main monitor. . It will be mostly used for gaming, watching bluerays and other random stuff like this. Im aiming for a 23/24" 120Hz one that has the same quality picture. I am however worried about (not sure if its called this..) shadow detail. I have had monitors in the past that show no detail in dark scenes or dark objects. That is the one thing i wish to avoide with the second monitor.
What actully causes this?
What is the best way to tell if a monitor will have this problem?
This is the monitor i have at the moment.
samsung t240
Display Screen Size
24" wide
Resolution 1920 x 1200 (WUXGA)
Brightness 300 cd/m²
Contrast Ratio DC 20,000:1 (1000:1) (typ.)
Response time 5 ms
Viewing Angle(Horizontal/Vertical)
160º / 160º (CR>10)
Colour Supported 16.7M
Signal Input Video Signal
Analog RGB, DVI, HDMI
Sync. Signal
Separate H/V, Composite, SOG
now lets say i bought the following monitor. Would the picture quality/shadow detail be the same/better as my current monitor?
Benq XL2410T 24.
Backlight Unit LED
LCD Size 23.6"W
Aspect Ratio 16:9
Resolution ( max. ) 1920 × 1080
Display Area ( mm ) 521.28 × 293.22
Pixel Pitch ( mm ) 0.2715
Vertical Frequency 120Hz ( max )
Brightness ( typ. ) 300 cd / m2
Contrast ( typ. ) 1000:1
DCR ( DynamicContrast Ratio ) ( typ. ) 10M:1
Viewing Angle
( L / R;U / D ) ( CR>=10 ) 170° / 160°
Glass Surface Anti-Glare
Response Time( Tr+Tf ) typ 2ms GTG
Special Feature Senseye® Human Vision Technology
Windows Compatibility Advanced Motion Accelerator
Technology ( Overdrive )
Yes
If the quality is the same/better id be more than happy to buy them. Ive noticed a lot are saying it isnt the best monitor in the world but it seems the best of a bad bunch. It doesnt have a gloss screen, its in my price range and it supports 120hz on hdmi (yay ps3
Im not really after any suggestions as the guys in the last post really helped me along that line. Im just tyring to learn if the picture quality would be the same as my current monitor. thanks for ANY help you can give. - Adam
samsung t240
Display Screen Size
24" wide
Response time 5 ms
160º / 160º (CR>10)
Sync. Signal
Benq XL2410T 24.
Backlight Unit LED
LCD Size 23.6"W
Aspect Ratio 16:9
Viewing Angle
Yes
) Im not really after any suggestions as the guys in the last post really helped me along that line. Im just tyring to learn if the picture quality would be the same as my current monitor. thanks for ANY help you can give. - Adam
