monitors that can go vertical?
14 May 2009
South East London
I'm looking for a monitor that can go vertical next to my 24" Samsung, does anybody know any monitors that can do that, I would want a 19 to 22" max
Thanks in advance,
Matthew
They pretty much all can :)
Most better quality makes have tilt and swivel stands that can tilt 90 degrees and even the ones that do not usually have what is called a "vesa" mount (4 holes on the back) that will allow a differant stand with this ability to be added.
Any monitor with this ability will likely say so in its description.
hmmm on just having a check im stunned by just how few monitors on sale here actually have full tilt and swivel stands so I guess the above is not that helpful :)
you can buy a neoflex LCD stand that fits on most monitors for about £35 just buy two stands they will do vertical on most 24" monitors, im considering doing that with 2 Benq G2420HDBL's as i dont have the desk space for 2 monitors side by side so vertical is the only way for me.
Thanks guys, I had a reply from overclockers who said "All our monitors except the Iiyama ProLite B2409HDS 24" Widescreen LCD Monitor and fixed stand and are unable to be adjusted." :(
and that's an idea EnderXi but I don't think all that works with the Samsung T240
