I recently decided to move over to a monowall based machine to act as my router, as my wag354g just seems to crash under any load or stall (doesn't give out ip address')
I currently have my monowall running (boots up, works ok, one nic is set to lan and the other, wan and the cables correctly plugged in accordingly) however im at a loss at how to convert my wag354g into a modem only box.
When it was the wag acting as the gateway i had it on 'PPPoA' however from what ive gathered this needs to be changed in order to use the monowall as the router.
In my wag i have the following options:
rfc 2516 PPPoE
rfc 2364 PPPoA
Bridged mode only
rfc 1483 bridged
rfc 1483 routed
which one do i choose so the monowall acts as the dhcp server/firewall/port forwarding etc?
On the monowall i have:
static
DHCP
PPPoE
PPTP
Bigpond
again, which mode do i select for it to work correctly.
I am on pipex solo 500 dynamic ip address service, if it helps.
Sorry if i have missed out on any essential info, im not very knowledgeable on networks.
Any input is greatly appreciated.
rfc 2516 PPPoE
rfc 2364 PPPoA
Bridged mode only
rfc 1483 bridged
rfc 1483 routed
static
DHCP
PPPoE
PPTP
Bigpond
