Monsoon 6 Packs
They supply one coloured to the fittings and one black set. Incase you don't want the O ring to match the fitting colour (for some reason). Something monsoon always do.
Also it can be quite easy to "nip" an o-ring and then end up with a leak.
Well, I just installed all my tubing and I have to say its difficult to tell when the monsoon fittings have had enough in terms of tightening. All of them are pretty much tightened all the way, but I didn't feel as if I was forcing anything.
I'll soon know when I fill it, which won't be tonight because if it leaks I don't want to ruin my new year celebrations!
I'll be sure to post back with the results when I get round to it. :D
