Hi there, can somebody just ease my fears a little! This is my first time custom building a loop rather than using a kit, the order is already placed with OCUk but I was just a little unsure on the sizes.
Fittings (no mention of the size, im assuming these are for 1/4" holes on the rad/pump/blocks?)
https://www.overclockers.co.uk/showproduct.php?prodid=WC-074-MO
Tubing (this seems to fit over the compression ends fine to me)
https://www.overclockers.co.uk/showproduct.php?prodid=WC-097-PM
Red/Pump combo (these have 1/4" outlets so im hoping the compression fittings fit....)
https://www.overclockers.co.uk/showproduct.php?prodid=WC-362-EK
Radiator (again, 1.4" so no isses here hopefully?)
https://www.overclockers.co.uk/showproduct.php?prodid=WC-077-EK
GPU Block (1/4" openings again so no issues?)
https://www.overclockers.co.uk/showproduct.php?prodid=WC-290-EK
CPU Block (No mention of the opening sizes, but EK seem to like 1/4")
https://www.overclockers.co.uk/showproduct.php?prodid=WC-203-EK
So yeah, will this all fit together? Im not a total noob, this is probably my 3rd WC setup, but the first one ive custom designed and also it will be a twin loop set-up, purely out of the desire to have it this way, let me know if ive made any boo boo's and il hopefully give you all a build log whenever OCUK decide to get the parts in stock, 4/20 items are out at the moment
And lastly, ive ordered some Mayhems concentrated coolant (https://www.overclockers.co.uk/showproduct.php?prodid=WC-052-MH) do I have to buy the Mayhems Pure H2O or can I just mix it up with de-ionised water (or distilled water), all the coolants ive ever bought have been of the pre-mix variety hence the silly question.
Cheers, Chris.
Cheers, Chris.
