Monsoon fittings
7 Mar 2016
On ocuk the monsoon hardline Fittings are in clearance and are really cheap. Not sure if this is anywhere else but I'm just wondering If this Is to do with a lot of people having leaks with their Fittings???? They are super cheap. Would love to buy them but the reports I have read and this massive price drop makes me cautious
my rig looked amazing, i then filled it will water all i can say is i called it my "Poseidon Adventure" imo i did a real neat job got the ends flat etc ( i bought all the tools / saws etc ) but it still had leaks. you have to be so precise its not true, i'd only do straight runs only if you have to, but in the end i thought the risk is to great, stuck my old hoses on and have never had a leak for 5 years. before and after i tried hardlines.
if you have the time and patience go for it, you will need to put it on test for a few weeks not days but if like me you need your pc up and running within 2 weeks forget it.
one thing i will say though is after i cut all the tube bent them and fitted them it did look stunning, very very neat.
