Hey guys, I'm looking for anyone who has used the Monsoon Hardline Conversion Kits.
I want to double check something. In the kit you get the 1/4" fitting to replace your barb fitting, a lock collar, two rubber seals per loc collar and an o-ring.
Now I'm assuming the o-ring goes onto the 1/4" fitting on the underside as normal, then one of the rubber "washer style" seals onto the face up side. Now my question is does the 2nd rubber washer go into the lock collar? Is it there to help seal the pipe to the collar even though you are gluing it?
I've watched a video on youtube and there is no mention of which seal goes where and it doesn't look like you put a washer between collar and pipe. So can anyone please clarify for me.
Thanks
EDIT Ok I just saw another video and defo no washer inside the collar so why do you get 2 washers per collar?
Thanks
