Monsoon temperature plug
30 Mar 2010
Exile
Evening.
Where does the Monsoon temperature plug go on a Crosshair Viii wifi motherboard?
I thought it went on the thermal sensor pins, but it doesn't fit because of the slow mode switch underneath it.
Evening.
Why doesn't it fit, is it not just a slim 2 pin connector, similar to those for the front panel switches?
Edit: looking at the photos on OCUK, the monsoon connector looks bulkier than all the other brands?
As you can see here on the Bitspower version it's the normal slim 2 pin connector:
https://www.overclockers.co.uk/bits...emperature-sensor-stop-fitting-wc-184-bp.html
Yeah there's groves on the underside that prevent it from fitting. The switch under it gets in the way.
https://www.overclockers.co.uk/monsoon-premium-g-1-4-temp-plug-matte-black-wc-139-mo.html
Really wanted to finish the build in the next couple of days, but the pins won't be accessible once I put in the hard tubing.
Edit: For the sake of a fiver I guess I may as well slice off the grooves with a Stanley?
Yeah I'd do that personally, if it doesn't work then just bin it and buy something else?
