I've now upped my budget to around £300 for a 20 inch widescreen monitor thing for use with an Xbox360.
Viewsonic VX2025wm 20" Widescreen LCD Monitor - Silver/Black - £281.99
Viewsonic VX2235wm 22" Widescreen - Price: £269.99
Belinea 102035W 20.1" Widescreen LCD Monitor - Black/Silver - £209.99
Looking at those monitor specs, they all look very good, but obviously I want one that's very reliable as I've never had one before and very worried about the dead pixels side of things. Which one would you recomend best for xbox 360? All those monitors compatible with Xbox360...obviously have to buy a cable from a shop or whatever.
Also is it relativily easy getting one replaced if the pixels do die?
Thank you for your help...
Needs to be around £300 or below.
Cheapest I can find is £318. If you have, don't say where btw, tis against the rules.
