be quiet! Silent Base 600 comes with Pure Wings 2 fans with only 0.76mmH2O rating, so even at full speed they struggle to move air through grill and filter. Arctic P series seem to be a decent fan. Some of first buyers who got their P series about 1.5 years ago have reported a few making bearing noise. So even if they don't last as long as others the price they can be replaced 2 or 3 times and still cost less than a top tier fan costds.
I suggest 2x 140mm front and 1x 140mm bottom intakes, block all opening in front half of case not covered by these intakes so the air they push into case has to flow through case and out, not leak around fans and go in circles. I would remove all PCIe back slot covers to increase rear vent area for better front to back airflow so lower temps with lower fan speed so quieter. No need for exhasut fans at all. Their increased noise level means when fans are slowed down to same noise level as with no exhaust fans system is same temp. If you search around you can find 5-packs of Arctic P14 for as little as twenty two quid, so you would have a couple spares to play with or save.
