I think what im after is Hairpin NAT but im not 100% sure.
Cisco ASA5505 (running version 7.2!!!)
I have 3 interfaces (security level next to each)
Outside (100)
Inside (0)
Guest (10)
Public IP - 1.1.1.1 - 1.1.1.2
outside interface on firewall is 1.1.1.1
Server on LAN is 1.1.1.2 by static NAT and ACL to https internal IP of this server is 192.168.88.107
fairly simply I want hosts on either the guest or LAN network to enter 1.1.1.2 and get to the internal address of the server.
I am trying to setup the LAN interface first but its not working and i dont know enough to troubleshoot the issue.
COnfig below
ASA Version 7.0(6)
hostname XXXXXXXXXXXXXXXXXXX
domain-name XXXXXXXXXXXXXX
enable password XXXXXXXXXXXXXXXXX encrypted
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 1.1.1.1 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.88.254 255.255.255.0
interface Ethernet0/2
nameif guest
security-level 10
ip address 10.99.99.254 255.255.255.0
interface Management0/0
shutdown
no nameif
no security-level
no ip address
management-only
passwd XXXXXXXXXXXXXXXXXXXXXX encrypted
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network LANNetworks
network-object 192.168.88.0 255.255.255.0
network-object 192.168.253.0 255.255.255.0
access-list 101 extended permit ip object-group LANNetworks 10.0.0.0 255.0.0.0
access-list 101 extended permit ip object-group LANNetworks 192.168.254.0 255.255.255.0
access-list 101 extended permit ip object-group LANNetworks 192.168.253.0 255.255.255.0
pager lines 24
logging enable
logging timestamp
logging emblem
logging buffer-size 409600
logging buffered informational
logging trap notifications
logging asdm debugging
logging debug-trace
mtu outside 1500
mtu inside 1500
mtu guest 1500
ip local pool VPNPool 192.168.253.1-192.168.253.254
asdm image disk0:/asdm506.bin
no asdm history enable
arp timeout 14400
global (outside) 2 interface
global (inside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 2 192.168.88.0 255.255.255.0
nat (inside) 2 192.168.253.0 255.255.255.0
nat (guest) 2 10.99.99.0 255.255.255.0
static (inside,outside) 1.1.1.2 192.168.88.107 netmask 255.255.255.255
static (inside,inside) 1.1.1.2 192.168.88.107 netmask 255.255.255.255
access-group acl_out in interface outside
access-group inside_access_in in interface inside
access-group Guest_access_in in interface guest
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
route inside 192.168.89.0 255.255.255.0 192.168.88.190 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 10
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec webvpn
password-storage enable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPN_splitTunnelAcl
default-domain none
split-dns none
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
client-firewall none
client-access-rule none
webvpn
functions url-entry
port-forward-name value Application Access
console timeout 0
management-access inside
dhcpd address 10.99.99.10-10.99.99.50 guest
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable guest
priority-queue outside
class-map inspection_default
match default-inspection-traffic
class-map guest-class
match any
class-map voice-qos
match access-list PriorityQueue
policy-map global_policy
class inspection_default
inspect skinny
inspect ipsec-pass-thru
inspect pptp
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
policy-map guest-policy
class guest-class
police 1500000 1000
policy-map outside_policy
class voice-qos
priority
class class-default
service-policy global_policy global
service-policy outside_policy interface outside
service-policy guest-policy interface guest
: end
help?
Outside (100)
Inside (0)
Guest (10)
COnfig below
ASA Version 7.0(6)
dns-guard
nameif outside
security-level 0
nameif inside
security-level 100
nameif guest
security-level 10
shutdown
no nameif
no security-level
no ip address
management-only
ftp mode passive
pager lines 24
logging enable
logging timestamp
logging emblem
logging debug-trace
mtu outside 1500
mtu inside 1500
mtu guest 1500
arp timeout 14400
banner none
wins-server none
dns-server none
vpn-idle-timeout 30
vpn-filter none
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
default-domain none
split-dns none
leap-bypass disable
nem disable
webvpn
functions url-entry
console timeout 0
dhcpd lease 3600
dhcpd enable guest
match any
class-map voice-qos
inspect skinny
inspect pptp
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
class guest-class
police 1500000 1000
class voice-qos
priority
class class-default
: end
help?
