Hi there
Check out the X1900 section:-
OcUK ATI X1900 Section
ATI Radeon X1900 ***Crossfire Edition*** 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-045-CO)
Is your rig ready for the onslaught of next generation games? It will be with the Radeon® X1900-the fastest consumer 3D graphics processor on the planet. Designed from the ground up to deliver maximum graphical detail at ultra-high frame rates, the Radeon X1900's state-of-the-art architecture includes an ultra-threaded engine for unparalleled shader performance. The Radeon X1900 ups the ante with Avivo™ video and display technology that delivers movies, games, and photos in high-definition with stunning color and realism.
This Crossfire Edition is a master card and is compatible with all brands of X1900 slave cards. Buy one of these cards and any slave X1900 XT or XT-X for the ultimate in 3D Performance and score upto 15,000 3D Mark 2005 points and have silky smooth frame rates at resolutions even upto 2560x1600 on the largest of monitors such as the DELL 3007WFP also available from this site. A Crossfire motherboard is also Recommended and OcUK recommends either the Asus A8R-MVP (Socket 939) motherboard or MSI RD480 Neo (Socket 939) Motherboard both which are available from this online store.
You won't find an X1900 Crossfire Edition card cheaper anywhere else! Be quick as at these prices stock won't last long
- Crossfire Edition Master card (Compatible with any Slave X1900 card)
- Crossfire Edition Motherboard required such as Asus A8R-MVP or MSI RD480 Neo
- 625MHz ATI Radeon R580 Core (X1900)
- 1450MHz GDDR3 Extreme performance memory
- 384 million transistors on 90nm fabrication process
- 48 pixel shader processors
- 8 vertex shader processors
- 256-bit 8-channel GDDR3/GDDR4 memory interface
- Native PCI Express x16 bus interface
- Dynamic Voltage and Clock Speed Control
- Ring Bus Memory Controller
- 512-bit internal ring bus for memory reads
- Programmable intelligent arbitration logic
- Fully associative texture, color, and Z/stencil cache designs
- Hierarchical Z-buffer with Early Z test
- Lossless Z Compression (up to 48:1)
- Fast Z-Buffer Clear
- Z/stencil cache optimized for real-time shadow rendering
- Optimized for performance at high display resolutions, including widescreen HDTV resolutions
***IN STOCK***
Price: £259.95 (£305.44 Including VAT at 17.5%)
BUY NOW
Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO)
Is your rig ready for the onslaught of next generation games? It will be with the Radeon® X1900-the fastest consumer 3D graphics processor on the planet. Designed from the ground up to deliver maximum graphical detail at ultra-high frame rates, the Radeon X1900's state-of-the-art architecture includes an ultra-threaded engine for unparalleled shader performance. In addition, it is CrossFire™ ready (Crossfire Edition X1900 Required), allowing your greatest multi-GPU fantasies to come true. The Radeon X1900 ups the ante with Avivo™ video and display technology that delivers movies, games, and photos in high-definition with stunning color and realism.
You won't find an X1900 XT graphics card cheaper anywhere else! Be quick as at these prices stock won't last long
- Crossfire compatible - Master Edition ATI X1900 card required!!
***IN STOCK***
Price: £239.95 (£281.94 Including VAT at 17.5%)
BUY NOW!
Connect3D ATI Radeon X1900 XT-X 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3055) (GX-046-CO)
Is your rig ready for the onslaught of next generation games? It will be with the Radeon® X1900-the fastest consumer 3D graphics processor on the planet. Designed from the ground up to deliver maximum graphical detail at ultra-high frame rates, the Radeon X1900''s state-of-the-art architecture includes an ultra-threaded engine for unparalleled shader performance. In addition, it is CrossFire™ ready (Crossfire Edition X1900 required for CF Mode), allowing your greatest multi-GPU fantasies to come true. The Radeon X1900 ups the ante with Avivo™ video and display technology that delivers movies, games, and photos in high-definition with stunning color and realism.
You won't find an X1900 XT-X graphics card cheaper anywhere else! Be quick as at these prices stock won't last long
- 650MHz ATI Radeon R580 Core (X1900)
- 1550MHz GDDR3 Extreme performance memory
***IN STOCK***
Price: £269.95 (£317.19 Including VAT at 17.5%)
BUY NOW!
These are stunning prices for a truly great card. Remember Connect3D is a tier1 partner so only use top yield chips etc. etc. and these prices are great buys!
***IN STOCK***
BUY NOW
***IN STOCK***
BUY NOW!
***IN STOCK***
BUY NOW!
