- 6 Sep 2016
How can you determine if adding a fan will improve or decrease cooling performance?
My case has three 12cm intake, a partially open side that is about 1 foot across mesh with another 12 intake, two 12cm exhausts. It has a top 8cm hole for an extra fan.
But I'm thinking of adding one or two 14cm holes for fans or down the road AIO
The placement of the 8cm hole is half way along the top. Is this bad, as air from the front could be pulled up? Maybe I should block that?
If I do drill holes for extra fans on the top, would it be best to place them far to the back as possible, so it's above the CPU and VRM area?
I'm thinking of enlarging the square for one or two 14cm fans, with AIO placement in the future for possible option later on
