evening all,
First all, a big thanks to the guys who helped me with my FTP issue earlier today.
Right, down to the nitty gritty...
I'm running a batch file with this inside..
This works fine, as in it connects to the server and runs the list of commands in the ftpscript.ftp file.
My problem is that the command's don't seem to match to what the log file shows happens.
contents of ftpscript.ftp
If I open a FTP connection in a sperate command prompt, and run though the commands listed in the ftpscript file, everything works perfectly. However when I run the batch file it fails.
Contents of log file
Can anyone shed any light on the subject??
Cheers in advance
Code:
@echo off
echo. >> log.txt
ftp -s:ftpscript.ftp ftp.myhost.com >> log.txt
echo. >> log.txt
pause
exit
Code:
username
password
ascii
cd Data/customer
prompt n
mget *.*
bye
Code:
Connected to ftp.myhost.com.
220---------- Welcome ----------
220-You are user number 3 of 50 allowed.
220-Local time is now 13:47. Server port: 21.
220 You will be disconnected after 15 minutes of inactivity.
User (ftp.myhost.com:(none)):
331 User username OK. Password required
230-User username has group access to: username
230 OK. Current restricted directory is /
ftp> ascii
200 TYPE is now ASCII
ftp> cd Data/customer
250 OK. Current directory is /Data/customer
ftp> Interactive mode Off .
ftp> prompt n
mget *.*
Syntax error in IP address
ftp> bye
221-Goodbye. You uploaded 0 and downloaded 0 kbytes.
221 Logout.
Cheers in advance
