Hi there
Some more excellent deals to finish of TODAY, make sure you check out our This Week ONLY deals, Festive Deal of the Day and TODAY ONLY Deals as well:-
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel (OCZ3G1333LV4GK) @ £39.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
Was [£49.99 Inc. VAT.] Inc. VAT
Only £39.99 inc VAT.
ORDER NOW
MSI GeForce GTX 460 HAWK "Talon Attack" 1024MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £154.99 inc VAT
MSI 460 GTX Hawk "Talon Attack" is a Special Limited Edition version of the record breaking 460 GTX Hawk. Comes equipped with a core specially selected to ensure maximum stability, 0.4ns GDDR5 super-high speed graphics memory and has enhanced default GPU/Memory/Shader clock speeds of 810/3900/1620 MHz (780/3600/1590 MHz in the original N460GTX HAWK). In 3DMark Vantage benchmark results, its performance surpasses that of the reference GeForce GTX 470, and with MSI's exclusive Afterburner (V2.0.0) overclocking software, triple over-voltage function, and all the military class features of the original hawk, this special edition truly punches well above it's weight class!!
- Triple Over-Voltage Adjustment
- The MSI N460GTX Hawk is the world's first graphics card to support voltage adjustment of the GPU, Memory and PLL making speeds, previously though of as impossible, easy to reach!
- Twin Frozr II Thermal Design 18 Degrees Celsuis Cooler and 8.1 dB Quieter!!
- Dual 8CM PWM Fans : Air flow from dual fans can cool down GPU/Memory/Power Module at once.
- Four heat pipes with SuperPipe Technology
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.
- 7+1 Phase PWM Design
- Higher current to GPU Powerv
- Higher overclocking capability
- Better stability in peak load
- Military Class Components
- Hi-C Cap provides more precise GPU voltage.
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.
- All Solid CAP for longer lifespan.
- APS (Active Phase Switching) & V-Check Points
- APS (Active Phase Switch) helps save power usage by controlling PWM automatically.
- V-Check Points allow users to read voltage directly by multi-meter.
Specifications
- Core Speed:</b> 810MHz (Beyond 1000MHz possible but not guaranteed)
- Memory Speed:</b> 1024MB 0.4ns GDDR5 3900MHz
- Shader Speed:</b> 1620MHz (Upto 2000MHz possible but not guaranteed)
- Memory Type:</b> 0.4ns GDDR5
- Memory Size(MB):</b> 1024
- Memory Interface:</b> 256 bits
- CUDA Cores:</b> 336 Units
- The world's first graphics card supports voltage adjustment of GPU, Memory, and PLL.
- 7+1 Phase PWM design provides extra 30A current output power to GPU for better overclocking power capability.
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- Reduces power consumption by switching of power phases dynamically when not in use (active phase switching)
- Support Over Voltage function of GPU, PLL and Memory
- Support advanced fan speed control.
- Support burn-in stability test.
- Support PhysX technology effects for realist physics effect.
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience
- Supplied with Full TOM CLANCY's HAWX2 PC Game as of 18/10/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
Was [£169.99] Inc. VAT
Only £154.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5830 1024MB GDDR5 PCI-Express Graphics Card supplied with AVP PC-Game @ £123.36 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5830 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 800MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Processing Cores: 1120
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
- Includes Alien vs Predator Voucher Code
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Was [£139.99] Inc. VAT
Only £123.36 inc VAT.
ORDER NOW
LG E2260V-PN 22" Widescreen LED Monitor - Black @ £164.49 inc VAT
The ultimate in LG Monitor displays is now available with the E60. Truly a marvel, it offers groundbreaking design elements, smart innovations like LED backligthing and the wonders of Full 1080p resolution. Imagine anything you might want in a monitor display and it’s been made a reality with the E60.
LG E60 Series monitors are backlit by LED lights. This gives colors a greater contrast and more vibrancy, and creates deeper blacks. It also allows the monitor to be slimmer and more energy efficient.
By supporting Full HD resolution and 1920 x 1080 pixels, the ideal conditions for media produced in a 16:9 format, the LG E60 monitor reproduces a myriad of images—from the minute movements of insects to thrilling videos games—in rich colors and elaborate detail.
You’ll love the stunning picture while it’s on and marvel at its appearance when it’s off. The super slim profile and seamless design will appeal to even the most refined sense of style.
The E60 Series has a 5,000,000 to 1 contrast ratio, allowing the monitors to recognize subtle color differences, as well as pitch blacks. You’ll experience more accurate colors, especially when you’re viewing videos or graphic-intensive applications with a dramatic contrast between light and dark.
Make installation of any enabled device a snap. Get 10.2Gbps of bandwidth for deeper colors and more to take advantage of the best Full HD experience. HDMI 1.3 connectivity lets you prepare yourself for tomorrow’s technology today.
Features
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- Weight: 2.8kg
- Warranty: 3 Years On-Site
Only £164.49 inc VAT.
ORDER NOW
LG E2360V-PN 23" Widescreen LED Monitor - Black @ £176.24 inc VAT
Energy Star is the U.S. government's international program that encourages the use of energy-saving consumer products.
Features
- LED Backlit
- Screen Size: 23" Widescreen
- Weight: 2.8kg
Only £176.24 inc VAT.
ORDER NOW
- 1333MHz DDR3
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
ORDER NOW
Specifications
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Features
- LED Backlit
- Weight: 2.8kg
ORDER NOW
Features
- LED Backlit
- Weight: 2.8kg
ORDER NOW
