More info on this lens please
23 Nov 2007
Midlands
Can someone give more info on this lens please and what sort of price it would sell for. Would it fit a modern canon ok? What is the extra black tube for?
Sigma 300mm 2.8
Sigma make lenses to fit all of the major SLR mounts, so you'll need to tell us what the printing on the lens barrel says to know what it'll fit.
The black tube looks like some form of lens hood, but is not for your Sigma lens, which looks to have one already mounted.
That looks like a really old lens - I can't find any mention of any Sigma 300 2.8's prior to their current black ones. If you could post a closer pic so we could get the various acronyms to go by as well we may be able to help. I'd doubt that this is a particularly strong lens simply because very few old Sigmas were, but the sheer amount of glass would probably mean it would fetch a few hundred pounds as a guess - it's always hard to value older or rarer lenses, particularly with very little detail.
Assuming it's EF mount (unlikely tbh), with Canon it probably won't work to autofocus it - the chip is probably out of date which will mean new cameras cannot autofocus it and there may be other errors, and there's no mention of it on the Sigma website so I doubt very much that they'll still produce parts to supply and service it.
The extra black tube is a lens hood to cut out stray light rays causing flares/ghosting, and for protection.
It looks like an early (late 80's early 90's) Sigma 300 f/2.8 APO lens. It could theoretically be an EF mount since that was introduced in 1987. Though it would be difficult to see from the picture. Can you post a better picture of the writing below the word Sigma, also one of the end of the lens that attaches to the Camera.
As Kasanti has already said if it is an EF Mount then due to it being so early it could potentially have problems working with newer Camera bodies (or indeed whichever brand of mount it has).
I manged to find this website which has three photographs - it looks like the lens in question.
http://www.dyxum.com/lenses/detail.asp?IDLens=354
One thing for certain, the chances are a lens of that size and that aperture in the 1980's 1990s probably would have retailed for a few thousand pounds.
What would be it be worth today? Who knows, certainly early White L FD series (the mount prior to EF) Canon lenses still command high hundred pounds into the low thousands. This obviously isn't a Canon built lens but If it is a particularly good Sigma lens (and dependant on the Camera mount) and rareity it could be worth quite a bit. Only a specialist second hand Camera dealer would be able to tell you.
Thanks very much for the info gents. The lens was for sale in a local second hand shop in town. It's now sold on ebay for £180ish
