more javascript woes. document.getElementById()
4 Jan 2004
Nottingham
more problems with simple things :(....really hate learning javascript
anyway...ive got a table in an html file thats got a different ID for each cell (numbers 1 to 26). In the js file ive got a for loop that puts 26 image locations into an array. after putting each image location into the array its supposed to put the image into the cell in the table using the document.getElementId() function but it wont. i keep gettin errors saying its set to null or is not an object etc, and in firefox's javascript console it says it has no property.
whats goin off???
heres my code:
html (btw i have added the .js file to the html before anyone asks me that :)):
Code:
</head>
<body>
<script language=javascript>
	createAlphabet();
</script>
<table border="1" <tr>
<td id="1"> </td><td id="2"> </td><td id="3"> </td><td id="4"> </td><td id="5"> </td><td id="6"> </td><td id="7"> </td><td id="8"> </td><td id="9"> </td><td id="10"> </td><td id="11"> </td><td id="12"> </td><td id="13"> </td>
</tr>
<tr>
<td id="14"> </td><td id="15"> </td><td id="16"> </td><td id="17"> </td><td id="18"> </td><td id="19"> </td><td id="20"> </td><td id="21"> </td><td id="22"> </td><td id="23"> </td><td id="24"> </td><td id="25" </td><td id="26"> </td>
</tr>
<table>
</body>
</html>
javascript:
Code:
var i;
var letter = new Array(26);
var source = "Images/";
function createAlphabet()
	for (i = 1; i<=26; i++)
		letter[i] = source + i + ".gif";
		document.getElementById(i).innerHTML = '<img src="'+letter[i]+'">';
i got sidetracked while i was looking at this for you, so i can't remember what i changed, but this works for me....
Code:
<html>
	<head>
			function createAlphabet() {
				for (var i = 1; i<=26; i++) {
		</script>
	</head>
	<body onload="createAlphabet()">
		</tr>
		<tr>
		</tr>
		<table>
	</body>
</html>
Its probably that your code is working onload, so the whole page exists. The first example will be running the javascript before the page is loaded, therefore the javascript cant find the elements in question :)
perfect, that was the problem. i was calling the createAlphabet function before the table was even created. put it under it and it works fine now :)
thanks both of ya
