More Maths Help
28 Jul 2003
The Moon
Right now this question should be easy but i am unsure as to what it is exactly asking for, I know how to complete the square but how should i display my answer, please help!
By completing the square, or by quoting the known facts in relation to a quadratic function, show that for all x E R
F(x) = -3x^2 + 6x -9 < -6
solve for the first derivative being zero. Input your solution then check that it is a maximum.
SoSolid said:
This is a completing the square question not differentiation one. Thanks any how though. :)
Well, says who? I appreciate if it's under a "completing the square" heading, then I suppose you ought to do it that way, but in any moderately decent exam or project then any valid method will be accepted.
If you want to complete the square, I suppose:
say:
f(x) = - (x^2 - 2x + 3) = - [(x-1)^2 + 2]
maximum value occurs x = 2, f(X) = -2
so F(x) = 3f(x) has maximum value at f(x) = -6
so F(x) < -6
would be a decent way of writing it
Or, differentiating:
F'(x) = -6x + 6
F'(x) = 0 => x = 1 => F(x) = -6
F''(1) = -6 < 0 , so this is a maximum point.
so F(x) < -6
Unless I've read it wrong
from
-3x^2 + 6x -9 < -6
Re-arrange to make one side 0, then work from there.
chill out.
SoSolid said:
chill out.
Nothing to chill out about, just pointing out that there's nothing wrong with differentiation - in fact it would probably count as "easier", since completing the square needs you to spot something in particular.
-3x^2 + 6x -9 < -6
0 < 3x^2 - 6x + 3
0 < x^2 - 2x + 1
0 < (x-1)^2
Ok sorry to steal your post but I'm revising GCSE chemistry and need help with answering a chemistry question. I've made two threads today so I thought I would just use this one since its kind of the same subject.
How in gods earth do I answer this? I can never remember.
daz, that's a horrible way to work it out. You're trying to show that the first line is correct, not show something else that follows from it.
That's a very easy question.
You can find the relative masses of each part of the equation:
ie C8H18 is 12*8 + 18, and so on.
So you will find something like x units of the fuel gives y units of CO2, then scale it up to 114g of the petrol.
And it's not really got much to do with the previous question :p
I wish I didn't procrastinate by answering these questions when I have impossible maths revision of my own to be doing!
Oh god, I found it hard :O. Thanks for the help. It was kind of the same, revision and helping with questions but thanks. I'll go shut up and practice now.
