More Problems
28 Jan 2005
Southport
hi all
You might remember about a week ago now i posted about my wheel viabrating really badly and recommended the tracking and balencing well i have had those done and the problem seems to have got better. Well what happens now is it wil be fine up untill 60 then it will shake till 70 then fine after that (not that i drive over the limit :p ). The strage thing is tho it wont do it all the time sometimes it fine and then when i take my foot off the gas it will shake through the 60s then stop. I cant seem to put my foot on the problem. I had the balencing done at one place and it still did it so i had all 4 wheels balenced and the tracking done at a garage I know near work and now it dose what i said above... :confused: :o
Any Ideas anyone...?
I've owned and driven loads of cars that did that. I just took to driving at 80 instead ;).
Lol so i take it its just one of those things, its better than it used to be at first it felt like my arms were going to fall off.. :eek:
I know i had a tyre upgrade when i bought the new alloys for it they are now Uniroyal Rainsport 195/45/VR15 dont know if that will make a difference it just had standard wheels and tyres on it before.
Corsa 1.2 "P" Reg
