I basically have a i9 7900x (delidded) a damn hot cpu currently being water cooled by a EK XE 360 radiator with a overclock of 4.6GHz at 1.22 voltage. Am currently hitting 86c on Aida64 (CPU,Cache & FPU Stress) with room temp at 25c. My question is adding a 2nd radiator maybe a 420 will i improve on the load temps? I mean if it's like a 2c or 3c improvement i rather just leave it. I know idle cpu temps cannot drop below ambient temperature but my current idle temps are also in mid 30's to high 30's a bit high also.
yes that's 97.8c something definitely wrong. My fittings the water block itself is very very hot. I mean this is a delidded cpu with a 1.22v getting cooled by a EK XE 360 radiator with 3 EK Vardar fans running at 2200rpm surely water temperature can't get this hot? Seems like everything is heating am in my case even the VRM is over 125c
