more seti gpu errors
3 Nov 2004
London
Well, I am getting a new batch of errors that seem to be confined to my 8600M on my laptop, anyone else getting this?
Code:
<core_client_version>6.10.18</core_client_version>
<![CDATA[
<message>
Incorrect function. (0x1) - exit code 1 (0x1)
</message>
<stderr_txt>
setiathome_CUDA: Found 1 CUDA device(s):
   Device 1 : GeForce 8600M GT
           totalGlobalMem = 253296640
           sharedMemPerBlock = 16384
           regsPerBlock = 8192
           warpSize = 32
           memPitch = 2147483647
           maxThreadsPerBlock = 512
           clockRate = 1600000
           totalConstMem = 65536
           major = 1
           minor = 1
           textureAlignment = 256
           deviceOverlap = 1
           multiProcessorCount = 4
setiathome_CUDA: CUDA Device 1 specified, checking...
   Device 1: GeForce 8600M GT is okay
SETI@home using CUDA accelerated device GeForce 8600M GT
V12 modification by Raistmer
Priority of worker thread rised successfully
Priority of process adjusted successfully
Total GPU memory 253296640	 free GPU memory 202346496
setiathome_enhanced 6.02 Visual Studio/Microsoft C++
Build features: Non-graphics	CUDA 	VLAR autokill enabled 	FFTW	USE_SSE	x86
     CPUID: Intel(R) Core(TM)2 Duo CPU     T7250  @ 2.00GHz
     Cache: L1=64K L2=2048K
CPU features: FPU TSC PAE CMPXCHG8B APIC SYSENTER MTRR CMOV/CCMP MMX FXSAVE/FXRSTOR SSE SSE2 HT SSE3
libboinc: 6.3.22
Work Unit Info:
WU true angle range is :  1.486721
After app init: total GPU memory 253296640	 free GPU memory 202346496
CUFFT error in file 'd:/BoincSeti_Prog/sinbad_repositories/LunaticsUnited/SETI_CUDA_MB_exp/client/cuda/cudaAcc_fft.cu' in line 139.
</stderr_txt>
I have not had any of these that I know of mate but if you think you have a bad batch I would
just disconnect from the project in Boinc Manager then re-connect and get a new batch of woo's.
