More sound problems when playing games - I can't get away from them!
2 Aug 2004
Hi,
I seem to encounter similar problems with most of the newer games I play. Stalker had a crackling problem which I fixed by using an older version of OpenAL32. Unfortunately I've now encountered a problem with Medieval II Total War.
When a voice plays over the top of the other sounds it frequently skips, which is pretty annoying. I can fix this by changing the sound to Miles Fast 2D Audio but I shouldn't have to use this as my card is a Hercules Fortissimo III which supports EAX2 and its drivers are up to date.
Can anyone offer an explanation as to what might be the cause of the problem?
Thanks.
v0id
