- 8 Dec 2012
- UK
Hi all,
Need some advice for a friend.
Situation:
Current network setup:
- PC 2 floors above router connects via powerline adapters (via ethernet).
- PS4 1 floor above router connects through wifi but signal not so great.
Query: He wants to put the PS4 on a powerline adapter setup as well. Will there be a massive impact on data flow having two nodes connecting via powerline adapters on the same electrical circuit?
And, is it best to use the same branded powerline adapters or stick to two different brands if this matters?
NOTE: Connecting via ethernet is not an option as cannot install cables.
Many thanks for advice.
Situation:
