- 15 Nov 2005
- topofthehill
hi
i know the basics, in that i need to check http://www.play-asia.com/paOS-00-3-xbox360_compatibility_guide-49-en.html to see if a game is compatible for a uk xbox, but i have a few questions that i dont seem to be able to find previously answered.
1) if the game is region free and sounds good to go, how does it work on live? will i end up playing on an asia server or will the game function just like the uk version for live purposes?
2) if there is an update for the game delivered via live, will this be applied ok?
3) or to summarise: if there is a tick against pal on the compatibility list and the language is english (or multi) are there any other considerations (even trivial ones) to be taken into account? or will the game function 100% the same as domestic uk version?
many thanks
craig
many thanks
craig
