Anyone seen any reviews, have or know of the most secure home router you can buy?
My current airport extreme does not support QoS and state package inspection.
(not fussed over wifi etc , gigabit ports a must!)
I meant from a Ethernet/internet point of way, IE firewalls etc.
Disable SSID broadcast
To go a step further, I would say build your own custom dedicated security box.
You really need to define what it is you want to secure over the basic NAT / firewall security features you get as standard.
It's possible to spend an astonishing amount of time on this though. If nothing else I'd recommend one of the off-the-net distributions (ipcop et al) rather than a diy approach, I've spent days reading through iptables and grsec information. This is a good link if you're willing to spend time on it.
My failure to do this competantly is why I still haven't implemented a 24/7 diy box.
I guess it's more a continuous way of learning rather than an instant out-of-the box approach to things.
