Most accurate of the two.
19 Sep 2019
My board, z370 Aorus Gaming 5 does not have the VR VOUT reading so I'm left with the other 2 on HWiNFO64.
I have always gone by the Vcore readings on the info panel that also shows the 3v, 12v & 5v etc..
A friend told me that I should actually be using the vcore reading on the lower of the 2 info panels that has the DDRVTT, PCH Core etc..
Can anyone verify what is the most accurate.
Thank you.
Can't remember what the LL settings are with giga 370 but just use cpu-z, check vcore on load. Won't be far off what you'd get with a MM. You've got between 1.3-1.35v to play sensibly so shouldn't matter too much for 24/7 unless you're pushing for freq / benching.
