Yeah that'll be an Intel socket 775 system that takes DDR2.
PC2-4200 or PC2-5300 will probably be enough, tho PC2-6400 may be just as cheap. You'll likely have to buy some that will run at 1.8v as I can't see the Dell having many tweaking options.
You would get away with this, tho it will probably run at PC2-5300 speed as it needs 2.1v to run at its rated PC2-6400 speed.
It'll be a little overkill as PC2-4200 or PC2-5300 would be more than enough for the CPU (and probably as fast as the system can run at), but it's usually just as cheap as the slower 2 models.
