So I'm dusting some old hardware off to build a file server for my home, but would like an efficient power supply to go with. Noise isn't an issue.
So the spec:
Intel P2 @ 350Mhz, 512MB ram, wired NIC, PCI SATA adaptor (not hardware RAID)
Four 2TB Green SATA drives.
...I think I'll be needing around 100watts; would I be far wrong with that guess? What'd you recommend for this? Looking at the FSP120-50GNF as with a fan fitted that ought to be fine.
Equally, what about a 120+watt PicoPSU; would one of those swing this kind of load 24/7 comfortably? Or would that be a bit too optimistic?
Cheers,
Blueacid
So the spec:
Cheers,
Blueacid
