- 25 Mar 2004
- Fareham
Evening all,
I live in a relatively small property, about the size of a 2 bedroom flat.
I have an "Ideal" Combi Boiler installed, and I have two thermostatic control units (wired up backwards by the builders!) in the property controlling the temperatures that the boiler heats the property up to.
Currently I have the heating coming on in the morning between 07:30 - 09:30 heating the property to 21 degrees, and in the evening between the same hours again to the same temperature. For the rest of the time it's not running the heating.
I'd really like to understand what is the most efficient way to heat my property, would leaving it on more often but heating to a lower temperature be more efficient?
I pay Scottish Power £60 a month DD, and I take meter readings every month. I have been using between £25-£30 a month on electric, and this last month about £30 on gas as well.
Any advice given is welcome. My shift patterns mean I can start/finish work up to 3 hours apart from week to week, but I can adjust the times the heating comes on relatively easily.
