Hey all,
Well getting my PC build soon, http://img90.imageshack.us/my.php?image=finalfinalspecre6.jpg (ended up changing OS to 64 bit...better be worth it!)
And i'm wondering what you guys would see as the most essential software/utilities to have / use on the build when its made.
Sort of like the essential utils that can be used to check things work the way they should, i.e temps, stats etc, just overall maintanence to ensure the build is running at the proper spec.
I looked at the Usefull Freeware Utilities thread above, but it is pretty huge and so much there
Was wondering what people use the most? Ill probably pop them on a USB pen ready for when it hopefully boots up with ease
