most silent high performance watercooling kit ?
Permabanned
19 Oct 2007
I would rather buy a kit if possible, sub £300
I need socket 775 x1, ati x1950 x1, northbridge cooling (think this is an extra zalman do one) possibly hard disk cooling ? not sure if its worth it for that ?
Should i buy a swift kit for £250 or an external one such as a zalman reserator ?
I plan to overclock, im happy with 2.8ghz on my e6300 (it can do 3.1 stable) and when i upgrade to quad core ill be happy with 3ghz.
I also plan to upgrade to a 3870 pro, will i need to change blocks or will the x1950 block work with it ?
what puts me off the reserators is that they have fancy dials and red led's, which is quite offputting when your trying to sleep in the same room as a pc thats running utorrent and BOINC 24/7
thanks
Thermochill PA 120.2 £49.99
DDC Pro with AC top £49.99
XSPC 5.25 Bayres £19.99
D-Tek Fusion £39.99
2x Yateloon D12SL £7.98
8ft Masterkleer £7.91
Bag of tie wraps £1.00
1ltr Feser 1 Coolant £7.99
Total = £184.84
....or you could buy the swiftech kit that will perform less and create more noise.
Dunno about cooling the NB as I dunno what mobo you have. But you have over £100 left to get a nb block and a gpu block which is perfectly feasable. Forget about HD cooling - simply not worth it.
