- 3 Mar 2010
- Highlands, Scotland
Hi folks, just after a bit of advice on an MOT advisory:
"Sub-frame corroded But Not Seriously Weakened"
Now my car is an 11 year old Vauxhall Astra, so this isn't a surprise, but I am hoping to keep it going for another couple of years at least.
I do all the servicing myself (brakes, oil, filters etc) and want to do something about this before it gets worse.
The garage told me to just clean it up with a wire brush, and then paint it.
Any advice with what to use? It does look a bit rough, but it's all surface rust and he said it's not that bad.
I was thinking about wire brushing it and cleaning it well, but don't want the bother of putting Deox Gel all over it.
Would Hamerite be ok? I know you get some that you can paint over surface rust after getting the loose bits off.
Has anyone done any similar work?
Thanks
Thanks
