Well the garage opens toms, so i will get the verdict.
Not filled with a lot of confidence now lol![]()
Found out what the damage is yet?
The only thing that doesnt make sense. If i put a rod through a block, why didn't the car lock up front wheels and skid???? As i am assuming the engine would seize up? And then wheels? Or is that because the clutch blew to pieces?
to be fair the gearbox synchros should have prevented that if your speeds are accurate.
was it playing up before this?
By playing up, do you mean.
Can knock it out of gear without using clutch?
And
Crunchy all the time?
^^^ Coz thats what it was like for the last 2 or 3 months
Yes.
I'd also be interested to know when you tried to start it if it was actually still turning, if so that's pretty rare not that it now matters mind you.
To be fair, music was still banging away, so i think it turned over, but dont know really
You can knock it out of gear at virtually any speed, and you can also get them back in at certain ones also, clutchless.
Crunchy all the time would be syncros or cable, how did the pedal and bite feel?
I'd be blaming your box for this.
There isn't a synchro on reverse..
We are talking about the gear you put it in to have done all this damage, i.e 2nd
How was it in selecting 1/2/3/4/5?
The bite ever change with heat?
Can you see what preventative maintence with this might have saved?
