- 23 Sep 2008
My little bit of cheap flimsy metal that cover the ports on the back of the case had little tabs on it for grounding. Im using an Eclipse 62 case, and must say the backplate dont fit that well, the ports arnt flush to it.
Anyway it seems that all the little tabs that ground the USB ports have broken off ( i found them on the table
) Is this a big deal? I assuming the tabs ground the backplate and the ports are grounded via mobo. Some tabs ARE touching the io ports, im guessing this will ground the entire thing.
DO they all need to be grounded? I dont want to risk the system for a cheap piece of metal, but the seem impossible to find with the right holes.
Thanks!
Noob system builder.
) Is this a big deal? I assuming the tabs ground the backplate and the ports are grounded via mobo. Some tabs ARE touching the io ports, im guessing this will ground the entire thing. DO they all need to be grounded? I dont want to risk the system for a cheap piece of metal, but the seem impossible to find with the right holes.
Thanks!
