Motherbard Upgrade Question
13 Dec 2003
Edinburgh
I'm considering a budget upgrade to my machine.
I'm only an occasional gamer so my AGP GF6800 will do me just fine.
I'm considdering the ASrock 939dual-SATA2 (ULi M1695) coupled with an Athlon 64 Bit chip to replace my Athlon XP 2800.
Questions are:
My Athlon XP 2800 is running @ 3200 speed, will I see much of a performance bump with a 64 Bit chip?
Which one gives the best bang for my quid?
Or should I look at a dual-core processor?
Current Set Up:
Mobo: WinFast K7nCR18D
CPU: Athlon XP 2800 @ 3200
RAM: 1024Mb DDR 400
GFX: Gigabyte GF6800, 128Mb, Silentpipe
Yours in anticipation
Jonny
How much money do you have?
What programs do you use?
If they're multithreaded then I'd get an X2 3800+ for £200
If not then a single core 3700+ for £140 would be a good buy
Both are great overclockers
Thanks ajgoodfellow
As I said I'm an only occasional gamer so purely brute power is not an issue.
I'm not a serious OCer either.
I use Photoshop (which I believe is multithreaded) and I'm starting to dabble in music & video editing so I expect the X2 is the best bet.
One more question.
I have an Antec True Power 380W PSU. I have, over and above the listed spec, 3 SATA drives, an NEC DVD writer and an Audigy 2 Platinum EX sound card, couple of 120mm case fans and an adjustable Gigabyte CPU cooler. No problems with power so far. Will the new mobo & X2 CPU need a bigger PSU?
Cheers
Jonny
Short answer would be - No.
Hyper 425 running X1800xt overclocked 165 opty 2 HDD's and 2 optical drives along with 3 fans.
Hyper 350 running x800gto2 overclocked 3200 2 HDD's 2 optical drives 4 fans.
Dual core definitely for video editing and photoshopping. Games will soon become more dependant on dual core as well.
x2 3800 should also be a decent overclocker if you decide on a free upgrade.
I agree with williamw11
Definitely get a dual core CPU for Photoshop (the later versions, CS and CS2 are multi-threaded). Your PSU, being a decent make, should be fine too
