Motherboad/cpu spec
31 Mar 2009
Stoke-on-trent
Having decided that i don't need the newer i7 cpu, i've decided to go with a quad core processor.
Can any one recommend a good cpu and motherboard combo + 6gb's of ram.
cheers
budget around £300 +
Intel Core 2 Quad Q9550 LGA775 'Yorkfield' 2.83GHz 12MB-cache (1333FSB) Processor - OEM £206.99 (£179.99)
Biostar TPower I45 Intel P45 (Socket 775) PCI-Express DDR2 Motherboard £111.54 (£96.99)
OCZ Gold Edition 4GB (2x2GB) DDR2 PC2-8500C5 Dual Channel (OCZ2G10664GK) £33.99 (£29.56)
Sub Total : £306.54
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 15% VAT : £47.41
Total : £363.45
Add a decent aftermarket cooler like the sunbeam if you dont already have one in your current rig, 4 gig of RAM should be fine btw
triffles no cpu cooler:(
that cpu will clock to 3ghz np you may want to buy a 3rd party cooler if you want to voerclock and only buy more than 4gb of RAM if you are running a 64bit OS:D
Intel Core 2 Quad Pro Q6700 "LGA775 Kentsfield" 2.66GHz (1066FSB) - OEM £142.99
Gigabyte GA-EP45-UD3P Intel P45 (Socket 775) PCI-Express DDR2 Motherboard - £133.39
OCZ Gold Edition 4GB (2x2GB) DDR2 PC2-8500C5 Dual Channel -£33.99
£310.37
