- 8 Oct 2011
Hi everyone
sorry for the long ramble below but I need some expert advice.
I recently bought 2 HD 6970s to put into crossfire on my motherboad (ASUS P6TD Deluxe) but as the cards are just that bit wider I found it was hitting the SATA connector and wouldnt sit correctly - unless I used a hammer
I would like to not have to upgrade again for 18 months or so
I currently have a core i7 920 (2.66 Nehalem), P6TD depulxe
ram 6gb DDR3 2000mhz pc3
CoolerMaster ACTS 840 case (so roomy)
So it looks like I need a new MoBo:
Question I have for everyone - should I bother moving to the latest chipset or just stick with the x58 for the time being?
If I stick with the x58 which board should I purchase that will have the room to fit these rather chunky graphics cards in crossfire
And which CPU cooler should I get as my Titan TTC Fenrir is a bit nosiy (trying to get something quieter if possible)
If I change chipsets then again which board, processor and cooler should I get?
btw I also have a sound card (XFI fatality) which I am very fond of so would like a slot free on the board to cram it on as well
I do like ASUS boards but will go with your recommendations
Any advice gratefully appreciated
