Motherboard and CPU cooler for 7950 Crossfire?
25 Mar 2004
Fareham
Hello,
I am planning to get a new motherboard and CPU cooler for my system to go with the rest of my components.
Components:
PSU: Be Quiet Dark Power Pro 850W
GPU: 2 x HIS 7950 in Crossfire
RAM: Teamgroup 16GB (2 x 8GB) 1600Mhz
CPU: Intel Haswell i7 4700k
Case: Corsair 650D so supports full ATX or mATX.
So I was thinking for mobo, the GA Z87X-OC Z87 board:
Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-434-GI
For the CPU cooler:
BeQuiet Dark Rock 2 CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-004-BQ&groupid=701&catid=2330
Ideally I want to have good spacing for the GPU's in Crossfire to keep the temps low. Also to have both PCI-E slots running on as high a bus speed as possible.
So will these meet my criteria?
1. Good spacing on the board for Crossfire GPUs?
2. Enough space to fit the CPU Cooler leaving a big enough gap between it and the top GPU?
3. Crossfire PCI-E bus speeds remain good (when using Crossfire on this board will they both run at 8x or 16x)?
I will only be applying a mild CPU overclock, but this board looks good for the money and is within my budget.
Good choice in cooler, I had the Dark rock pro 2 and it was the best air cooler I have owned. It is very big though so space between the top GPU and the CPU cooler might be close.
I couldn't really see the difference between the Dark Rock 2 Pro and the Dark Rock 2 - except that the Dark Rock 2 Pro had an extra 120mm fan. Maybe other differences too but OCUK only have the Dark Rock 2 in stock at the moment anyways.
