hmm thats not that problem then, I have just built the below spec and for some reason when i turn it on i dont get anything on the screen also when the dvd drive is plugged in via IDE it does not work but when there is just power to it it works!!
Akasa Ultra Quiet 400W Paxpower Active PFC ATX2.2 Power Supply - Black Nickel
Gigabyte GA-M61PME-S2 (Socket AM2) PCI-Express DDR2 Motherboard
AMD Athlon 64 X2 Dual Core 4400+ 2.40GHz (Socket AM2) - OEM
Seagate Barracuda 7200.11 160GB SATA-II 8MB Cache - OEM (ST3160813AS)
Coolermaster Elite 334 Case - Black (No PSU)
Asus DRW-2014S1 20x DVD±RW IDE Dual Layer (Black) - OEM
Corsair 2GB (2x1GB) DDR2 Value Select PC2-4200C5 Dual Channel (VS2GBKIT533D2)
Akasa AK-876 CPU Cooler (Socket 754/939/940/AM2)
Strange one, few things to check whether you have done these or not .
Are all power connectors installed including the 4 pin for cpu power, try each memory module individualy to check if you have a faulty stick and try a CMOS reset.
