Motherboard and PSU combo for MiniITX
24 Jul 2003
South East Coast
Hello,
I'm building a computer for my friend and he decided he liked the BitFenix Prodigy which means I have to go the MiniITX route. He has already bought the case, RAM (Kingston Hyper Grey 8GB) and an SSD. He has 5 SATA hard drives currently sitting in a USB storage unit so ideally those plus the SSD all need connections although it looks like unless we 'modify' the removeable hard drive bay to fit in the graphics card we will have to remove the bays. That leaves only 2 3.5" HDD bays so potentially only 3 SATA connections will be used.
The CPU will be a 3570k and a AMD 7850 2GB which will be OC'ed. Now i'm a bit stuck on the motherboard as there seems so little range as I want to pair it with a Z77 chipset. Although there is an Asus H77 board for about £83 with 6 SATA connections I am tempted by the Gigabyte boards as I use one myself but the limit of 4 SATA ports total means that the only way to deal with this in the future is to buy a new board completely.
He also needs a PSU to go with the setup, I have a 650 watt in mine but am not sure if he needs all that as MiniITX is more efficient I believe.
Problem is we are currently buying a few components every month and we've decided on the motherboard and PSU but he wants to spend as little as possible without compromising quality too much which makes it a difficult choice as i'm knowhere near familiar with ITX boards and recommended PSU's enough.
Any general help/advice/recommendations appreciated.
The Asrock Z77E-ITX is probably going to be what you settle on, overclocks like a demon and doesn't break the bank.
The Gigabyte Z77 ITX boards have no vcore adjustment due to only having 4+2 power phases (at least that's Gigabyte's official excuse for it)
You can be a bit limited with what coolers fit either of these boards, only the Asus which isn't worth the premium over the Asrock can take just about any high end cooler.
PSU, in all honesty 450-500w is overkill for what you intend to put in the Prodigy but you get some good prices on psu's of this size.
160mm long is maximum, to still leave you 20mm to deal with cables.
I'd advise no longer than 140mm to make life easy.
If you're really stuck.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-052-BQ
I've used that before with an overclocked i5 and 7850 build, whisper quiet and being semi modular you just use the cables you need, nice and tidy.
Hello,
I hope I can help.
The Zotac H67 can do 5 SATA's. 2 of which are SATA3.
http://www.zotacusa.com/zotac-h77-itx-wifi-h77itx-b-e.html
(+1 esata)
A user has rotated his hard drive rack to house the hard drives.
Essentially, you will look like this:
http://www.tonymacx86.com/user-buil...deluxe-16gb-2400mhz-ram-ga-radeon-hd6870.html
Hope this helps.
Edit: Asus with 6 is better... Don't mind me..
