motherboard and psu question
18 Oct 2002
lancaster
have just got a new motherboard to upgrade from my old abit ic7-max3 board that just has a 20 hole atx connector from the psu.
now looking at my new board there is a 20 plus a 4 connector, do i therefore need a new psu as well.
according to the manual it has a eatxpwr - 24 pin and a 4 pin atx12v
my psu is a atx so i thought it was the same but looks like this is differnt
Yep it is different. Your old PSU 20pin ATX connector will fit 20 of the 24 pins on the new motherboard fine. You'll need a 4 pin atx12v as well though, does your PSU not have a 4-pin "P4 connector"?
i dont think so will need to double check otherwise will be buying a new psu as well. my psu is four years old now anyway.
