Motherboard antenna replacement
22 Nov 2014
I recently broke the antenna that came with my Gigabyte GA-Z87N-WIFI (rev1) motherboard and could use some help finding a replacement.
I found this on amazon http://www.amazon.co.uk/dp/B001PSB5...UTF8&colid=ZR1EA58FJ1L9&coliid=I3GZ7RZV7Z5M7H, is it the kind of thing I should be going for?
The motherboard wifi card doesn't support 5Ghz as far as I'm aware so am I right in thinking there's no point getting an antenna that does? Also, the motherboard has two circular connectors for antenna(s), does this mean I should buy two in the case of the antenna linked above as I notice it only have one connector?
I wasn't sure whether this belonged in networks or motherboards so apologies if I got it wrong!
